Fixt•© 2025
Published: Feb 23, 2024—3 min read
Local Voice Assistant: Using your Cameras & Speakers in HA
PrerequisitesInstall it on the Home Assistant ServerPiperWhisperOpenWakeWordInstall it on a Different ComputerWyoming IntegrationConfigure Assistant Stream AssistConfigure Stream AssistWake Word Detection BeepAndroid IP Camera App
Ultimate ESPHome DIY Smart SensorUltimate ESPHome DIY Smart Sensor
Voice-Assistant
Piper
Whisper
OpenWakeWord
  • Docker Installation
  • WSLPorts
Piper & Whisper & OpenWakeWord
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-local-voice-assistant.yaml
to run it
docker compose up -d
Wyoming Integration
Ports:
  • Piper 10200
  • Whisper 10300
  • OpenWakeWord 10400
Stream Assist
By AlexxIT
Beep used on the video.
Open your Home Assistant instance and browse available media.
to run it
media-source://media_source/local/beep.mp3
RTSP Configuration
rtsp://admin:[email protected]:8554/live
Voice-Assistant
Voice-Assistant
